Inband Signaling
Anyway my question is:
Our system crashed so we reinstalled voice guide and copied all the files over to the new installation.
Everything seems to work fine except for Inband signalling.
Here is a snip of our logs and it appears that the inband filter is not found:
180621.34 4 ScriptEventCode 49 iLineState=4100
180621.34 4 LsIndialSignalCapture 1 *400120
180621.34 4 timer set 0.5 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
180621.82 4 timer fired EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
180621.86 4 ScriptEventCode 9011 iLineState=4100
180621.86 4 LsIndialSignalCapture EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT *4001201
180621.86 4 Inband *4001201 not matched by any patterns
180621.89 4 timer clear
180621.94 4 [start] Playing
180621.94 4 [start] Playing ()
180621.94 4 ScriptEventCode 8001 iLineState=1100
180621.95 4 LsPlayMsg EV_PLAY_FINISHED
180621.95 4 timer set 10 EV_TIMEOUT_HANGUP
180621.95 4 timer set 1 EV_TIMEOUT_GOTOMODULE
180621.96 4 RunModule PLAY end
180623.04 4 timer fired EV_TIMEOUT_GOTOMODULE
180623.04 4 ScriptEventCode 9002 iLineState=1101
180623.04 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
180623.05 4 timer clear
180623.05 4 [Evaluate Inband Signaling] Evaluate [$RV[inband_Info]]
180623.05 4 rv replace start: [$RV[inband_Info]]
180623.06 4 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Whiztocoho\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Whiztocoho}[$RV_STARTTIME]{10/18/2007 6:06:18 PM}[$RV_DEVICEID]{4}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}
180623.06 4 rv replace end: []
180623.07 4 .Eval()
180623.09 4 rv add [Evaluate Inband Signaling_Input]{}
180623.10 4 rv add [Evaluate Inband Signaling]{}
180623.22 4 Eval Expr result:[]
180623.22 4 rv replace start (strlen>500)
180623.22 4 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Whiztocoho\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Whiztocoho}[$RV_STARTTIME]{10/18/2007 6:06:18 PM}[$RV_DEVICEID]{4}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Evaluate Inband Signaling_Input]{}[Evaluate Inband Signaling]{}
180623.23 4 path {} not found
180623.24 4 timer clear
180623.24 4 [start Time Switch] Time Switch []
180623.24 4 [Thursday, October 18, 2007 18:06] does not fall within [09:00-17:30 on MoTuWeThFr]
180623.25 4 timer clear
180623.27 4 [Whiz to Nighttime] Playing
In vg.ini I have:
;Inband signalling configuration file eg: InbandSignaling_SiemensHiPath3000_v1.2.txt
;Inband signalling detection is enabled on Enterprise versions of VoiceGuide only.
InbandSignalConfig=C:\Program Files\VoiceGuide\InbandSignaling_nitsuko_384i.txt
and that file is there.
Any suggestions would be appreciated
It looks like the PBX is sending Inband signaling to VoiceGuide. We can even see in the trace log what the sent information is, and that it did not match any of the patterns defined in the Inband Signaling Configuration file:
You’d' need to have a look at the Inband Signaling Configuration file to see why none of the entries in it matched the *4001201 message sent by PBX.
Please post your Inband Signaling Configuration file (the file: C:\Program Files\VoiceGuide\InbandSignaling_nitsuko_384i.txt) and we can have a look at the pattern definitions in it as well and better comment on how the InbandSignaling_nitsuko_384i.txt file should be modified to correctly interpret PBX's messages.
Here is the file. I believe this is the same file I used before the system crash
; Inband Signaling definition file for:
; Siemens HiPath 3000 v1.2
; Each Inband Signal definition entry consists of two lines: Pattern and RV
; Pattern :
; Any string expression conforming to the pattern-matching conventions described in
; Visual Basic for Applications LIKE operator pattern definition.
; Used to match the incoming Inband Signalling data.
; RV :
; VoiceGuide Result Variables extracted from the matched Inband Signalling stream
; multiple RV's are specified using 3 fields per RV:
; 1. Name
; 2. Start Postion
; 3. Length
; Result Variables extracted
; List of Result Variables extracted using this definition file:
; Inband_TOC = Type of call (TOC)
; Inband_Calling = Calling party
; Inband_Called = Called party
; Inband_Info = Additional calling party information
;Origional Incomng call
Pattern=[*][6][0][0]#
RV=Inband_Info,1,4,Inband_Line,5,1
;Plain Transfer
Pattern=[*][5]######
RV=Inband_Info,1,2,Inband_Calling,3,3,Inband_Ext,6,3
;Busy Transfer
Pattern=[*][4]######
;key 1080 DND Transfer
Pattern=[*][3]######
;700 Check Voice Mail
Pattern=[*][1]###
RV=Inband_Info,1,2,Inband_Ext,3,3
;Check Voice Mail button
Pattern=[#]###
RV=Inband_Info,1,2,Inband_Ext,2,3
;Ignore
Pattern=[*][*][*][1]###
RV=Inband_Info,1,4,Inband_Ext,5,3
;Take Message
Pattern=[*][*][*][2-5]######
RV=Inband_Info,1,4,Inband_Calling,5,3,Inband_Ext,8,3
;Line ID
Pattern=[*][*][*][6]###
RV=Inband_Info,1,4,Inband_line,5,3
;Record
Pattern=[*][*][*][8]###
;Record
Pattern=[*][8]###
RV=Inband_Info,1,2,VmbId,3,3
;Hangup
Pattern=[9][9][9][9]
RV=Inband_Info,1,4
;User Login
Pattern=[#]###
RV=Inband_Info,1,1,Inband_Ext,2,3
It is a bit strange. Would have expected the *4001201 message to match the [*][4]###### pattern...
Which version of VoiceGuide is installed on this system?
Try adding this pattern to the Inband Signaling definition file:
Pattern=*4######
It does work now.
I had two files and I was calling the wrong one. It works perfect now
Thanks!
